03-06-2007 05:35 AM
03-07-2007
08:24 AM
- last edited on
03-26-2025
08:36 AM
by
Content Cleaner
Hello Jamesponty,
Currently, LabVIEW MathScript cannot be used on real-time targets. We are considering adding support in a future release of LabVIEW, but at this time, we have no specific date when it will be available. For reference, you may find the following documents helpful in determining which features are unsupported on LabVIEW RT targets: https://www.ni.com/docs/en-US/bundle/labview-real-time-module/page/real-time-operating-systems-real-...
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
04-22-2013 08:45 AM
I have the exact same question.
Now, several years later: Is it possible with the 2012 version?
Would it be possible if I use a *.m file, which I connect via a MATLAB (R) script node? (I have a licensed version installed)
Thanks!
Keks
04-22-2013
12:44 PM
- last edited on
03-26-2025
08:33 AM
by
Content Cleaner
Ohrkeks wrote:Now, several years later: Is it possible with the 2012 version?
Well, mathscript is now called Matscript RT and realtime targets are supported. (See also).
Ohrkeks wrote:Would it be possible if I use a *.m file, which I connect via a MATLAB (R) script node? (I have a licensed version installed)
What is "it"? Are you trying to run a matlab script node on RT? I think that only works on windows, not RT.
04-23-2013 03:12 AM
Thank you! 🙂
