LabVIEW Interface for Arduino Discussions
why onboard LED is stays on
Hi, I'm new to LabVIEW Interface for arduino and was wondering how I can turn off the onboard LED, because it seems when i upload the firmware to the arduino board it sets pin 13  high
(3,867 Views)
I've not experience this issue before but you can manually turn it off after you run Init.vi.  Simply set the pin mode to output and then write false to that same pin.
(3,164 Views)
thanks it worked
(3,164 Views)
