LabVIEW Interface for Arduino Discussions
stepper motor interface with labview and arduino
Hello everyone
i am having problem with my coding. I have to make the stepper motor rotate accordingly. i am sorting object where specific QR code are stick on it.
However, when the qr code on the object is scanned, the motor should rotate to a certain degree and then go to the home position. and when scan another object, it should rotate as well and then return to the home position.
when i am trying it in my GUI, like with the scanning all that. it is not working properly
But i did try my motor circuit with the lIFA for the example of stepper in the labview which work perfectly. when i give a certain angle, the motor rotate.
Can some1 help me please. i will be really grateful.
My GUI and image processing for the QR code is in labview where i use vision acquisition and Vision assistant to make it work,
(3,978 Views)
Hi Zahkay,
Since arduino is a third party device and the features provided to interface with are too, National Instruments doesn't bring support to it. That why I would like to strongly recommend you to please redirect this question but in the LabVIEW discussion forums rather than here in the community. For doing that follow this link:
http://forums.ni.com/
You can also type arduino in the search bar of that section of the website and try to search for a similar case to discuss or compare better your case.
That is because you will be interacting with a lot of experienced users that can orient you to develop your application.
Best regards
(3,313 Views)
Dear Sir
thank you for replying, i try to put it here. is it okie now sir
http://forums.ni.com/t5/LabVIEW/stepper-motor-interface-with-labview-and-arduino/td-p/2828596
Hope to hear from you soon
Best Regards
(3,313 Views)
