LabVIEW Interface for Arduino Discussions
set up a Max and Min value to turn on a pump...
Hi, I started to play with my arduino and labview program since a couple of weeks. I managed to read and log my analog signal on my computer but now it is getting more difficult.
I will add a (Max & Min) value into my program to turn on a pump (digital on) depends on my analog value from my sensor? I also want to have 2... repeated cycles for my program.
Let's say:
1- start the program the pump goes on
     the value is increasing to 50 (Max)
2- the pump stopped
     the value decreases to 10 (Min)
3- the pump goes on again to value 50 (Max)
4- repeat the cycle 2 or 3 times
Can someone help me to run the program or give me some hints.
I'm more than happy over every comment.
Regards, Markus
(3,806 Views)
The overall system that you describe can be done with a state machine.  It looks like you are trying to implement an on/off controller so that is something you might consider looking up.
(3,316 Views)
