LabVIEW Interface for Arduino Discussions
problem with arduino-leonardo i cant compiling the LIFA_base
i'm new in the use of arduino
and when i trying to use LIFA_base this show me
LIFA_Base.cpp.o: In function `loop':
C:\Users\Alfre\Desktop\arduino-1.0.4/LIFA_Base.ino:59: undefined reference to `checkForCommand()'
C:\Users\Alfre\Desktop\arduino-1.0.4/LIFA_Base.ino:65: undefined reference to `sampleContinously()'
LIFA_Base.cpp.o: In function `setup':
C:\Users\Alfre\Desktop\arduino-1.0.4/LIFA_Base.ino:39: undefined reference to `syncLV()'
and when y use
the AFmotor.acc i see the next error
AFMotor.cpp:97:5: error: #error "This chip is not supported!"
AFMotor.cpp:114:5: error: #error "This chip is not supported!"
AFMotor.cpp:134:5: error: #error "This chip is not supported!"
AFMotor.cpp:152:5: error: #error "This chip is not supported!"
AFMotor.cpp:173:5: error: #error "This chip is not supported!"
AFMotor.cpp:190:5: error: #error "This chip is not supported!"
AFMotor.cpp:213:5: error: #error "This chip is not supported!"
AFMotor.cpp:230:5: error: #error "This chip is not supported!"
AFMotor.cpp: In constructor 'AF_Stepper::AF_Stepper(uint16_t, uint8_t)':
AFMotor.cpp:334: error: 'CS20' was not declared in this scope
i need maybe some steps to comunicate my arduino-leonardo with labview
i need some help, i want control a pair of servomotors
i add the librarys that i am using
(12,839 Views)
See post 10 here.
Let us know if that helps.
-Sam K
LIFA Developer
(6,489 Views)
i modified the last Version of the Firmware. Now Stepper with Leonardo works '
-> You just need to ADD "Leonardo" in the LabVIEW Init VI.
(6,489 Views)
My arduino micro is working with LIFA, stepping motor also.
I've changed some parameters for leonardo chip set. not sure for IR(actually I skip)
Procedure:
1.download Following driver
2.extract to %~~~%\LabVIEW 2013/vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\
3.Sketch LIFA.ino with arduino skecher
4. Use LV original arduino sub VIs. it's working!
Goog Luck
(6,489 Views)
Hi, im using arduino pro micro, downloaded driver from last post, but labwiew not found my arduino (error 5005)
Please help.
(6,489 Views)
Creo Que ESA es La Gran Respuesta, junto a Otras correocomo tuve creoq ue lo lograre solucionar! buneo muy pronto les informare como me fue, gracias por el LIFA esta buenisimo
(6,489 Views)
can you please tell me where to get the same for Arduino Atmega8...???
(6,489 Views)
