LabVIEW Interface for Arduino Discussions
lsm303dlhs acc with labview - incorrect/diffrent readings
Hi
I'm using the lsm303dlhs accelometer  with arduino and labview for some car navigation project.
I checked the reading of the accelometer in arduino and got readings that are [0 ,0, 1035] (X,Y,Z axis)
but when connecting arduino to labview ' getting different results in Z axis [0,0,1400] ,thats 350 diffrence in Z axis.
I’m using the VI that published Nathan_B. for interfacing with the arduino and the sensors, and it worked without a problem, but the different readings worry me...
Who gives the right reading? Why there is, a different reading?
can’t understand that…
anyone encountered that?
I'm using MEGA and labview 2012
(4,923 Views)
I can't find any information about a LSM303DLHS.  Can you post a link to the datasheet?  Also, which set of VIs are you using?
(4,140 Views)
Hi
the link to the datasheet is here :http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/DM00027543.pdf
and the vi I run is  "Graph Data" from you  post here: https://decibel.ni.com/content/thread/18077
tnx for the fast respond
(4,140 Views)
Could you post the Arduino code that you are using (where you got [0,0,1035])?
(4,140 Views)
thats the code, and I added the sensors serial print at the end
#include <Wire.h>
#include <L3G.h>  //Gyro
#include <LSM303.h>  //Magnometer + Accelometer
L3G gyro;
LSM303 compass;
//CONSTS
#define D2R 0.01744f
#define R2D 57.324f
//Compass Vars
float heading_az;
int ax,ay,az;
//Prints
char report[80];
//-------------------------------------------------------------SETUP------------------------------------------
void setup()
  Serial.begin(9600);
  Wire.begin();
  //Gyro
  while (!gyro.init())
    Serial.println("Failed to autodetect gyro type!");
  gyro.enableDefault();
  //Compass
  compass.init();
  compass.enableDefault();
  compass.m_min = (LSM303::vector<int16_t>){
    -460,   -372,   -491            };
  compass.m_max = (LSM303::vector<int16_t>){
    +321,   +453,   +227            };
//---------------------------------------------------------------------MAIN------------------------------------------
void loop()
  compass.read();
  ax = (int)((compass.a.x/(16)));
  ay = (int)((compass.a.y/(16)));
  az = (int)(compass.a.z/(16));
  heading_az = compass.heading((LSM303::vector<int>){
    -1, 0, 0    }
  )*D2R;
  snprintf(report, sizeof(report), "Acc[X,Y,Z]: %3d %3d %3d AZ %3d",ax,ay,az,(int)(heading_az*R2D));
  Serial.println(report);
(4,140 Views)
