LabVIEW Interface for Arduino Discussions
interface labview with arduino UNO
The data sheet for AD 9850 is http://www.analog.com/static/imported-files/data_sheets/AD9850.pdf.And actually I have written the code that can use keypad as a input to the arduino to control the AD 9850,but my lecture asked me to develop a GUI to control the arduino instead of using keypad,my arduino code with keypad is as shown in the attachment,but I dont know how to use LAB view to interface with Arduino and between I have created the labview for the AD 9850 and I dont know how to interface with the arduino,actually to control the Ad 9850,we need to set 4 pin:pin reset,pin freqeuncy updata,pin clock and pin data(32 bit data serial ) according to AD 9850 data sheet.Sorry,I am newbie for interfacing arduino with labview,that why I am headache on how should i start?.
(4,912 Views)
Start by installing the Labview Interface for Arduino.  This frequently is called LIFA.   To install LIFA go to this page.
<https://decibel.ni.com/content/docs/DOC-15971>   There you will find the Labview Interface for Arduino Setup Procedure.  Follow the instructions to install LIFA.    Installing LIFA also installs some LIFA example In your copy of Labview.  Try some of the examples to get familiar with LIFA.  Near the top of the Documents page there is a link to a Labview Interface for Arduino FAQ that is worth reading.  The documents page also contains a list of LIFA examples.
hrh1818
(3,724 Views)
This is being discussed here: https://www.labviewhacker.com/forums/viewtopic.php?f=12&t=17&p=70#p70
I plan to post an example in that thread and eventually provide VIs for the AD9850 as part of LINX.
-Sam K
LabVIEW Hacker
Join / Follow the LabVIEW Hacker Group on google+
(3,724 Views)
