LabVIEW Interface for Arduino Discussions
how to create condition loop?
You can set the pin values after the while loop but before you close the Arduino.
Message 31 of 37
(1,955 Views)
Hi sir, hope you can help me on the lcd data print. When I put the print vi in the circuit, the data obtained was wrong. How to correct the print vi? Please advice. The image below show the temperature value that I obtained.
Message 32 of 37
(1,955 Views)
The LCD VIs should not affect the analog pin's voltage.  The best advice I can give is to test to see if the example LCD VIs works with your LCD and then add the analog pin to it if it works.  Also, you should try using the USB cable for testing to eliminate a possible failure point.
Message 33 of 37
(1,955 Views)
Hi Nathan, thanks for your reply. My LCD work well in the example with both USB cable and Xbee. But when I add the "LCD PRINT vi" to it, it show impossible value..
Message 34 of 37
(1,955 Views)
Hopefully, the suggested solution that you found here will fix it.
Message 35 of 37
(1,955 Views)
Hii sorry for my late reply. it works well with the VISA resource.. thank you!!
My project almost completed with your help. Thank you so much. But now I want to improve it by using two xbee communicate with one coordinator. But seems Labview Interface for Arduino just can read from one router at one time. Any possible way to read two routers?
Message 36 of 37
(1,955 Views)
I'm not all that familiar with LIFA+XBee but I'm guessing no.
P.S. Since the topic of this thread has been resolved, you should create a new discussion or look at existing discussions regarding XBee.
Message 37 of 37
(1,955 Views)
