LabVIEW Interface for Arduino Discussions
arduino and bluetooth hc-06
how i can start the conection betwen arduino and bluetooth hc-06 i find a video on youtube  http://www.youtube.com/watch?v=d5fWPqX3uDA the bluetooth in this video is the same
i need conecto this bluetooth because i have a proyect and i dot want controller my arduino whit a cable 😕 please help me
Message 1 of 10
(9,988 Views)
Have you find a solution to connect bluetooth module to arduino??
Message 2 of 10
(8,274 Views)
What do you mean with "start connection"?
The physical connection?
¿A qué te refieres con "iniciar la conexión"?
¿A la conexión física?
Message 3 of 10
(8,274 Views)
i need control servo motors and step motors. RC model
Message 4 of 10
(8,274 Views)
If you talk about the physical connection, here you have an schematic...
I do not know if you talked about that.
Message 5 of 10
(8,274 Views)
Thanks, me question is how to pair pc with Buetooth module in Labview. I want for example turn on LED over a Bluetooth connection  .Maybe you know the steps what i must to do? I found my bluetooth COM4 in VISA, trying to run program,  bluetooth module trys to pair, LED stop flashing, but i get error. 5003.
Message 6 of 10
(8,274 Views)
Hi dovis.
Maybe I misunderstood your requirement, let me share with you the next link.
In the tutorial you can see how to pair the bluethoot module with your PC.
I hope that instructions can help you.
It would be fine if you show the error message, maybe you could take a screenshot to show the error.
Please, if the answer is correct, choose the "Right answer" button.
Regards
http://www.instructables.com/id/Add-bluetooth-to-your-Arduino-project-ArduinoHC-06/?ALLSTEPS
Message 7 of 10
(8,274 Views)
Message 8 of 10
(8,274 Views)
Thanks, i will try.
Message 9 of 10
(8,274 Views)
Verify the baudrate of the Bluetooth, I read something related with that characteristic.
You can use the AT commands to check it in the Bluetooth module.
Message 10 of 10
(8,274 Views)
