LabVIEW Interface for Arduino Discussions
Xbee, Arduino uno, LVIFA
Im trying to wirelessly communicate data from my arduino board to the Xbee connected to the computer. Im trying to get the data to come up on my VI, but im getting nothing. The 2 xbees do communicate with eachother, and the VI works when not wireless. I have the baud rate for the xbees set at 38400, but I think the arduino is set to 115200. Is that a problem? If so how do you change the baud for the arduino uno? Any help is appreciated. Thanks.
(4,474 Views)
i doubt xbee dont support baud rates of 38400 range
Electronics and Instrumentation Engineer
Freelance LabVIEW and Arduino programmer.
For projects contact me ; djac791@gmail.com
(3,469 Views)
I also have the same problem. My goal for using xbee is to have real time processing with labview, but I couldn't get xbee to communicate to my arduino. My Xbee is comunicating fine. As most people who have been playing around with Xbee, they know that baud rate should be 9600 in most case. In order to make it work, I followed many people instruction, I have my labview code pointed to Xbee with 9600 rate. I setuped my xbee with XCTU. and the last thing i have to fix was my arduino code. I believe my code on arduino mess up the comunication from xbee to arduino; the xbee Serial communication info.
How i wired it is : Laptop-> Xbee USB -> send data wirelessly -> Xbee connect-> Arduino Mega
My quesiton: Is anyone know how to fix the code on the arduino that originally in the Directory : ../Labview Interface with Arduino/... to be able to use Xbee on labview
If you have any idea please help. I have this problem for long time and don't know who to ask for help.
Thank you!
waiting for the answer
(3,469 Views)
