Hi Magesh I can't get this to work. First of all I notice on SolidWorks the Rotary Motor1 is greyed out and i get two conflicting messages when try to deploy from Labview :
"Access Denied. The NI Scan Engine is already in use by another process. The other process might be a LabVIEW project or a built application. Please close that project or application and try again. If you are attempting to run a built application from a project that has already started the scan engine, you need to close and reopen the project and run the application before deploying another project item."
"The SolidWorks assembly contained in the LabVIEW Project and the open SolidWorks assembly are not synchronized_ Verify that the model is correct and right-click the SolidWorks assembly item in the LabVIEW Project Explorer window and select Synchronize to SolidWorks to synchronize SolidWorks and LabVIEW_"
I located the assembly file quite fine and I have clicked on Synchronize to assembly. Yet when I try to deploy after it doesn't deploy.
Can you help me through this problem. Ultimately all I want is this servo to be controlled by an arduino analog pin.
