LabVIEW Interface for Arduino Discussions
Repertory Firmware not found
I've just installed LIFA with ViPM and there are no repertory Firmware in <LabVIEW>\vi.lib\LabVIEW Interface for Arduino\
Where can I find it, please ?
Pierre
Message 1 of 8
(6,417 Views)
I assume when you say repertory Firmware you mean LIFA Firmware.  Others have reported this problem and Sammy_K has provided a solution.  What you need to do is:
Look for the discussion topic "Where is LIFA Base Pde for Labview 2012"
Open this discussion toic and scroll down to Sammy_K message, the last message.
Download the Zip file, LIFA_Base_2012_Build_79.zip
Unzipping this file produces  the LIFA_Base_2.1.1.69  > LiFA_Base folder
The LIFA_Base folder contains the LIFA firmware
Howard.
Message 2 of 8
(4,911 Views)
I don't know what "repertory" means but I think this thread will help you.
Message 3 of 8
(4,911 Views)
I'm in the same boat; the Firmware folder doesn't exist within <LabVIEW>\vi.lib\LabVIEW Interface for Arduino\.
Running LV 2011 on my end.
I'm going to keep searching online and in other folders on my machine.
Support: would the locatio of the IDE changed with a new rev of the library?
Laughlin
Message 4 of 8
(4,911 Views)
The code on this site does a pretty good job giving output both in g's and angle of rotation about the three axis of rotation.
http://www.electronicsblog.net/simple-angle-meter-using-adxl335-accelerometer-arduino/
Converting the Arduino code to LabView should be trivial if you're familiar with the more Arduino 'language'.
Cheers,
Laughlin
Message 5 of 8
(4,911 Views)
Look fot the last message in the "Where is LIFA base pde for Labview" discussion topic.  Sammy_K attached the firmware to this message.  It is labelled LIFA_BASE_2012_Build_79,zip.
Message 6 of 8
(4,911 Views)
The package in VIPM should be updated to include the firmware now.
-Sam K
Message 7 of 8
(4,911 Views)
At 1320 PST, I downloaded the current LIFA package with the VI Package Manager. The firmware still show's as Arduino v2.2.0.78 so we must be patient a little longer.
JohnCS
Message 8 of 8
(4,911 Views)
