LabVIEW Interface for Arduino Discussions
Problem of reading Encoder
sorry there is not error in encoder library but there is error in firmware codeCapture.PNG
Message 11 of 13
(1,023 Views)
I  edit the code and there is another error
Message 12 of 13
(1,023 Views)
Because I wrote it for an older version of LIFA, there were quite a few changes required to update it.  Also, I completely removed Encoder.cpp entirely when I implemented it.
So, I've updated it but for convenience I had to modify Encoder.h so you have to use the version as I have it in the archive.
To use this, you need to compile my custom firmware and upload it to your arduino and then you can use the VIs.
EDIT:  I've created a document with my encoder code here:  https://decibel.ni.com/content/docs/DOC-30184.
Message 13 of 13
(1,023 Views)
