LabVIEW Interface for Arduino Discussions
Power Spectrum Error When Running Arduino
I am fairly new to labview and even newer to using it with arduino.  I have been largely successful with running my project until I attempt to output my LED's from Labview to my arduino.  Once I have it set up in manner attached below I recieve a 1931 error from my Power Spectrum VI which states that my number of samples must be greater than zero.  Yet once the arduino vi's be removed I no longer recieve such errors.  I am wondering if anyone else has had similar problems or has a large enough understanding to aid me in my predicament.
(5,050 Views)
When posting VIs, first save them for an earlier version of LabVIEW (preferrably 2009) so that more people can open them and attempt to help.
(4,340 Views)
This should hopefully clear up that little problem. Unless I saved it wrong.
(4,340 Views)
What do you mean by this:
What do you remove to get it not to error?
(4,340 Views)
Down at the bottom If i delete all the arduino VI's labview will run but then i wont be outputting to the arduino board.  I managed a work around by moving the arduino write out into its own loop and then using a Read local variable to run the output.
(4,341 Views)
That is very strange.  Could I see how you are now doing it with your work-around?
(4,341 Views)
