LabVIEW Interface for Arduino Discussions
Showing results forĀ
Search instead forĀ
Did you mean:Ā
PROBLEMA AL COMPILAR LIFA_BASE
holis q tal tengo el siguiente problema al compilar el LIFA_BASE recien empiezo a usar arduino...tengo la version Arduino 1.0.5:
LabVIEWInterface.ino: In function 'void processCommand(unsigned char*)':
LabVIEWInterface.ino:150: warning: left shift count >= width of type
C:\Program Files (x86)\Arduino1\Arduino\libraries\LiquidCrystal/LiquidCrystal.h:117: error: 'void LiquidCrystal::init(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)' is private
LabVIEWInterface:362: error: within this context
(5,176 Views)
You should consider using LINX instead.  It is newer and it is currently supported (LIFA is no longer officially supported).
(4,045 Views)
hola buen dia, podrias probar al utilizar otra version de arduino a mi me funciono  la 1.0.2. Sino has modificado nada del LIFA BASE(asegurate que sea el oficial), pasate a la primera pestaƱa y solo dale en la opcion cargar (no lo compiles) solo cargalo y listo(al paracer se compila al cargar). Espero que te sirva, a mi me sirvio. Saludos
(4,045 Views)
