LabVIEW Interface for Arduino Discussions
Moisture Sensor Arduino Labview Water Pump
I'm attempting a basic control project to irrigate a plant based on soil moisture readings using a moisture sensor, to Arduino to Labview Software and start stop a water pump to irrigate the plant based on moisture readings. That's the plan anyways..
So far will use an Arduino Uno, open to change Arduino if an alternative works better, I need to source an Arduino compatible moisture sensor, water pump, cables, tubing. I will use  Labview 2019 witth LIN and Arduino compatible compiler installed. I have a limited eperience of Labview but not so familiar with Arduino hardware or using Labview with Arduino. For now I've been referring to Programming Arduino with Labview by Schwartz and Manickum plus some ccollege notes and managed to get Arduino LED blinking using Labview VI.
I have a few questions: If I find Arduino code to run parts of my project is there a templaate that allows me to create VIs to run the program using Labview instead of the code? Will the hardware configuration be same running in Arduino code as using Labview?
Any other advice would be greatly appreciated.
Message 1 of 1
(3,547 Views)
