LabVIEW Interface for Arduino Discussions
Making a installer with Arduino linked via Xbee
I am working on a project in which arduino is interfaced via XBee. I would like to know if I make a installer file for the same project so that it could be installed on any system will I need to install any other divers other than the VISA drivers which will be anyways be included in the installer file.
Your support will be much appreciated.
Thank you.
(4,236 Views)
When you use the xBee, does that require Arduino drivers?  If yes, then those will need to be installed separately.
(3,789 Views)
Thank you so much for your reply Nathan. Yes it is requred to install the drivers of Arduino before it could be interfaced with the XBee. So is there any way of including those drivers with the installer so that the end user need not install is serparetly ?
(3,789 Views)
In previous discussions regarding the same question, the answer was no.  However, I can't personally confirm this, you never know, they could have added new features to the newer versions of LabVIEW.  That is probably a question more suited to the general forums: http://forums.ni.com/
(3,789 Views)
