LabVIEW Interface for Arduino Discussions
Low-cost motion control
Hi everyone,
I would like to build a low cost motion control for positioning using micro-controller.
Coordinates receive from LabView via serial communication for positioning.
I plan to use Arduino+Ramps 1.4 because it can 5 control stepper motors, axis (x,y,z), E0 & E1.
Planned axis setup to the platform is X1,X2,Y,Z, rotatable axis.
In total 4 axis & 1 rotatable axis.
Is this concept can be done?
Thanks.
Vision+M4_w0
(4,620 Views)
Hi all !
Please advise me to merge these two vi's. I want to have Inspection controls and G-code sender controls on one front panel. I have tried to copy palettes from one to other, but the front panel will stuck.
I think they cannot run simultaneously, so i need suggestions to overcome the stuck problem but getting Inspection controls and G-code sender controls out on one front panel.
Thanks in advance.
*G-code sender is from LabVIEW G-code Sender Thanks to おおはし it is really help me a lot
(4,479 Views)
Hi again.
I have tried this method and the program runs okay. If there is a more effective approach, please advise me.
Now I am trying to use (Measure) command in G-code sender to switch inspection steps
(4,465 Views)
