LabVIEW Interface for Arduino Discussions
Low Frequency PWM
Attached is an example of a low frequency PWM.  Its nane is LowFrequencyPWM.VI.  The minimum period, on time + off time, is approximately 50ms.  The outut is on pin 9.  A different output pin may be used by changing the Digital I/O Pin value for the SetDigital Pin Mode and Digital Write Pin VIs
Howard
Message 1 of 1
(3,407 Views)
