LabVIEW Interface for Arduino Discussions
Leonardo interfacing with labview?
Hello all
I am using the Arduino Leonardo in conbination with labview,
does anyone know this is possible?
Greetings Paul
Message 1 of 10
(10,062 Views)
Hi Paul,
"I am using the Arduino Leonardo in conbination with labview,"
Have you tried hooking it up? Any activity?
Dale
www.GorillaBuilderz.com
Message 2 of 10
(5,906 Views)
Hello Dale
Thanks for reacting.
I hooked it up and when I uploaded the labview base frimware
it says that the AFM motor component is not reconized, chip is not supported.
I also see opening the firmware I get six tabs with alle code blocks for arduino in it
this is not as I see in the examples.
Programming leonardo with arduino interface works fine.
Paul
Message 3 of 10
(5,906 Views)
Hello again Paul.
Please try and upload examples and screenshots of what you are referring to. It is very hard to visualise exactly what problems you are having otherwise
Dale
Message 4 of 10
(5,906 Views)
Hello Dale
Underneath the responses(leonardo connected)
from the compiler selected Uno or Leonardo
Arduino uno selected:
avrdude: stk500_getsync(): not in sync: resp=0x00
Arduino Leonardo selected:
AFMotor.cpp:97:5: error: #error "This chip is not supported!"
AFMotor.cpp:114:5: error: #error "This chip is not supported!"
AFMotor.cpp:134:5: error: #error "This chip is not supported!"
AFMotor.cpp:152:5: error: #error "This chip is not supported!"
AFMotor.cpp:173:5: error: #error "This chip is not supported!"
AFMotor.cpp:190:5: error: #error "This chip is not supported!"
AFMotor.cpp:213:5: error: #error "This chip is not supported!"
AFMotor.cpp:230:5: error: #error "This chip is not supported!"
Paul
Message 5 of 10
(5,906 Views)
Ok Paul, now we can see where the issue is. The LVIFA does not support the new ATmega32u4 chip. Basically you will either have to wait for the Labview crew to update the library, do it yourself or you can select UNO from the IDE dropdown list and see if 1)it compiles and 2)if you can run a simple say LED blink test?
So I guess in answer to your original query...
I guess the answer is 'No', not easily.
Dale
Message 6 of 10
(5,906 Views)
There is now an answer in this thread:
Labview for Arduino Leonardo??
Message 7 of 10
(5,906 Views)
im not able to use it whit the instructions given in that link
Message 8 of 10
(5,906 Views)
Message 9 of 10
(5,906 Views)
Now this is the error:
C:\Program Files (x86)\Arduino\libraries\RobotIRremote\IRremoteTools.cpp:5: error: 'TKD2' was not declared in this scope
For LIFA_Base
What's wrong?
Message 10 of 10
(5,906 Views)
