LabVIEW Interface for Arduino Discussions
Labview with Teensy 3.1
Hi
I've been using Teensy 3.1 for about a week now on my project and it has been great so far. Initially, I was using the Arduino Uno for about a month and had to switch to Teensy 3.1 for its faster Serial.write speeds.
I'm currently taking it to the next step and add a Labview interface. I managed to set up my Labview software to work with the Arduino and did a simple blinky test and it worked fine. I had to use the Labview for Arduino Interface library to get this working.
Now, I am trying to set up the Labview to work with the Teensy.
I followed the steps on this page : https://www.pjrc.com/teensy/languages.htm
This modified Arduino code allows Teensy to work with LabVIEW's Arduino library.
I assume this is the same as the aforementioned library that is tweaked to work with the Teensy.
I extracted the file from the .zip and opened LVIFA_Base.ino. With my Teensy 3.1 connected, i tried to upload the .ino code but received the following error:
Click image for larger version.   Name: Screen Shot 2015-01-07 at 4.20.15 pm.png  Views: 0  Size: 32.5 KB  ID: 3255
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Arduino: 1.0.5-r2 (Windows 7), Board: "Teensy 3.1"
AFMotor.cpp:94: error: #error "This chip is not supported!"
AFMotor.cpp:108: error: #error "This chip is not supported!"
AFMotor.cpp:125: error: #error "This chip is not supported!"
AFMotor.cpp:140: error: #error "This chip is not supported!"
AFMotor.cpp:158: error: #error "This chip is not supported!"
AFMotor.cpp:172: error: #error "This chip is not supported!"
AFMotor.cpp:192: error: #error "This chip is not supported!"
AFMotor.cpp:206: error: #error "This chip is not supported!"
In file included from AFMotor.cpp:13:0:
AFMotor.h:121: error: 'CS01' was not declared in this scope
AFMotor.cpp: In constructor 'AF_Stepper::AF_Stepper(uint16_t, uint8_t)':
AFMotor.cpp:310: error: 'CS20' was not declared in this scope
I've been stuck here for some time and can't find any way around this.
Any advice?
Thanks in advanced.
Message 1 of 1
(4,346 Views)
