LabVIEW Interface for Arduino Discussions
Labview mega2560 Serial1&2&3 not found pls~
Hello, Dear all
There is a project currently, we need to read 2 messages about the consecutive Polling signals by Mega2560 with LabView as attachment. Please indicate us how to add Serial 1 and Serial 2 in the Program.
Thank you in advance and looking forward to your prompt reply.
(4,040 Views)
Serial communication via Serial 1 and Serial 2 are not supported by LIFA.  You would need to create custom functions that execute that code, but it must fit into the command/response architecture on which LIFA is based.  I.e. it must be able to send a command and receive the response from Serial 1 or 2 relatively quickly (you would not be able to constantly poll the port).
(3,429 Views)
Hello, Dear Nathan_B:
Thank you for your kind and prompt reply. However, There is something need to figure out, so you mean that I have to write the way of communication Serial 1 or Serial 2 in the LIFA_Base? Do you have any example to share with me.
(3,429 Views)
You have to create a custom function.  I would recommend starting by duplicating an existing function in the LIFA firmware and in LabVIEW (with a new command number).  Make sure that works first.  Then, you can add your own custom code to that function instead of the code that you duplicated.
(3,429 Views)
