LabVIEW Interface for Arduino Discussions
Labview for Arduino Leonardo not communicating
I'm new to Arduino. I am having trouble connecting Labview 2014 32bit with Arduino Lenardo. I've updated my NI-Visa to 19..., I've followed the instruction to the T for LINX by Digilent/LabVIEW MakerHub Installation and testing. My observation, at point when I do the Compile and Load I don't see the TX & RX LED blinking on the arduino as indicated. I check the log and I get;
avrdude_ard.exe: Version 6.0.1, compiled on Mar 30 2015 at 14:56:06
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "avrdude_ard.conf"
Using Port : COM6
Using Programmer : avr109
Overriding Baud Rate : 57600
avrdude_ard.exe: ser_open(): can't open device "\\.\COM6": The system cannot find the file specified.
avrdude_ard.exe: ser_send(): write error: sorry no info avail
Any ideas of what I need to check?
Note; the Arduino IDE appears to be working fine using COM6.
I've tried un-install/re-install LINX by Digilent/LabVIEW MakerHub
I can see Arduino on Ni-Max. I don't know what commands to send it to test it. I have tried ATI but I got an error.
(4,233 Views)
you should install ide 1.0.1 version
(3,263 Views)
