LabVIEW Interface for Arduino Discussions
Labview control Arduino to output specific voltage
Hello
I want to design a Labview code that can not only measure the voltage of the circuit, but also give instruction to the arduino uno board that the board can provide the specific voltage. In the attach vi file, the voltmeter part has been designed.
According to the designing of the Arduino IDE code, the specific voltage can be set by using the code "AnalogWrite", and the voltage is proveded from PWM Pin. But the amplitude of the PWM waveform will not change, so the designing of the specific voltage for Labview has failed. May I ask how can I design to provide specific voltage from 0-5V by Labview?
This problem has comfused me for a long time. I would really appreciate your help.
Thank you very much!
David
Message 1 of 1
(3,080 Views)
