LabVIEW Interface for Arduino Discussions
Labview + arduino + relay control to control pneumatic piston
I'm new to labview and i am trying to make a program to control the move of a pneumatic piston,
I managed to control relays with labview but when i activate switch to open piston it opens then the program stops and doesn't work anymore can't .... anyhelp?!
(4,071 Views)
Since LIFA is old and no longer supported, I'd recommend that you upgrade to LINX for communicating with your Arduino.  After doing so, and you are still unable to get it to work, please post on the LINX forums.  When you post on the forums, you will  need to provide more information especially including any errors that you get when you run your VI.
When using LINX, you won't need to set the "pin mode" which will probably solve your problem.
(3,956 Views)
