LabVIEW Interface for Arduino Discussions
Labview 2019: No connection with Arduino Mega 2560
want to start a communication between new installed Labview 2019 and Arduino 2560.
But it will not work. Only the RX-LED on Arduino is blinking for 30 seconds.
All required settings are done properly.
1. LIFA-Base (Labview Interface for Arduino)  is installed
2. Com-Port is set correctly
Is there something I forgot...?
I would be thankful for a little help !!!
best regards
Christoph
(5,138 Views)
Can you please indicate what interface you are using? are you using LINX?
I could not find the Arduino interface and the LINX for Labview 2019? it does not appear in the NI package manager
(5,066 Views)
as I wrote I use the LIFA-Base (Labview 2019  32 Bit) coming with the VI-Package Manager
and the Arduino IDE v1.8.9 .
Next I want to try Labview 2018 and perhaps an older Arduino IDE....
(5,047 Views)
Hi Maass, please see my thread:
https://forums.ni.com/t5/LabVIEW/LabVIEW-Tutorials-Programming-an-Arduino-using-LINX/m-p/3959118#M11...
I have posted several videos on how to program an Arduino using LabVIEW and the LINX add-on. The only variation will be you would have to select the Arduino 2560 in the LINX firmware wizard (see tutorial 1).
Please let me know if you have any questions.
Best Regards,
Sin | Electrical Engineer & Principal Consultant
(5,006 Views)
