LabVIEW Interface for Arduino Discussions
LabVIEW Interface for Arduino: Stepper Motor Example
I am trying to run a stepper motor using LIFA's "Arduino Stepper Motor.vi" but can't get the VI to control my motor.
Specifications:
Stepper Motor: NEMA-17 size - 200 steps/rev, 12V 350mA, https://www.adafruit.com/product/324
Arduino Board: Arduino Uno, http://arduino.cc/en/Main/arduinoBoardUno
Motor Driver: EasyDriver Stepper Motor Driver, https://www.sparkfun.com/products/10267
Power Supply: 9.6V, 300mA wall wart
I have tested my stepper motor using the example Arduino code, but I want to control the motor with LabVIEW. I have flashed the LIFA_Base firmware on the Arduino and then tried to run the "Arduino Stepper Motor.vi"...but nothing happens. I am attaching a screen shot of the VI (slightly modified to show that I am using COM5 for my case) and a picture of my electrical setup.
Please help me identify my problem. Thanks!
Note: I apologize for the poor picture quality (but it's been labeled for clarity)
(11,342 Views)
Try swapping the step and dir leads at either the Arduino board or at the easy stepper board.  The default settings in the VI show 2 at the top and 3 at the bottom of the input pin control. This setting outputs the step signal on Arduino's pin 2 and the direction signal on pin 3,   Whereas the Fritzing diagram shows the Arduino's pin 3 is the step signal and pin 2 is the dir signal.
hrh1818
(6,246 Views)
HOW TO CONTROL A PICK AND PLACE ROBOT USING STEPPER MOTOR
(6,246 Views)
That is an extremely broad question.  One that doesn't have a simple answer.  If you have issues with some code using LIFA, please start a new discussion and explain what exactly you are having trouble with.
(6,245 Views)
