LabVIEW Interface for Arduino Documents
LabVIEW + ARDUINO = Installing LabVIEW Interface for Arduino (LIFA) + Example (servo control)
Requirements:
  1. LabVIEW: VI Package Manager (http://jki.net/vipm) + LabVIEW Interface for Arduino (LIFA)
  2. ARDUINO (https://www.arduino.cc): Arduino UNO Rev3 + L293D Motor Drive Shield
  3. Servo motor: TowerPro SG90 Servo
Comments
HallmannSVS
Member
Member
on
Do you have some examples Labview and Arduinio + Ramps1.4 e.g. control a stepper? are there some tools for labview to work with an ramps 1.4 board?
KaremAbuowda
Member
Member
on
Dear,
If the arduino is MO type  https://store.arduino.cc/arduino-m0. This kind is based on micro USB cable. How to initialize the connection? I tried to use all of the three available types but no one works?
Regards
niklins
Member
Member
on
Hi!
I was wondering if it´s possible to connect an analog microphone to Arduinon? And then connect the Arduino to my computer (MAC) and when you say a word in the microphone the computer will make an recursion om the a sound or a it could be that the  sound makes a video start playing, does anyone one have the codes for this and suggestion  on how to do this?  TECH SPEC ARDUINO UNO and Macbookpro 2016.
Best Zea
rschemmel
Member
Member
on
I was able to install the Labview arduino interface support so "arduino" shows up as a menu but could not get
the LVIFA_Base file to load on my arduino. I tested my arduino IDE by loading and running the blink example
and that worked but I got several errors when trying to load the LVIFA_Base.pde file.
Robert
Contributors
