LabVIEW Interface for Arduino Discussions
LVIFA through Transceiver
Hello, everyone. I need to make my robot wireless...
I need help with:
  1. Adding code to the LVIFA base to communicate with transceiver
  2. Coding the transceiver on the robot to receive and execute commands from the transceiver and to transmit data to the transceiver
Has anyone done this before? I have a showcase in less than 2 weeks and it has to be done by then, so I would really appreciate any help!
(6,425 Views)
Hi ask.cristion.filwr, look I guess that you can do it with LIFA.
According to what I see in the configuration of the module, you have to do this in several steps:
1) You need to create a control algorithm for select the TX/RX switch.
2) You need to create a communication protocol for transceiver 1 and transceiver 2 (arduino's transceiver and robot's transceiver)
3) To make an interface between robot and LIFA (Labview)
I hope this text help you. This is a nice project, we wait ideas!!..
(3,204 Views)
