LabVIEW Interface for Arduino Discussions
LINX firmware wizard won't go to the next step
Hello!
I'm just starting with labview and I'm having problems communicating my arduino with labview. I downloaded linx and went to the firmware wizard and I get stuck there.
What am I doing so wrong?
Thanks in advance
(5,892 Views)
I think is a problem of baud rate only you muste to check
(5,816 Views)
Tried changing the baud rate, tried releasing the usb ports in case they were being used but still nothing. On windows the firmware wizard works, though I still can't get a connection. On my mac i can't even finish the firmware wizard
(5,808 Views)
Hi belinak, please see my thread:
https://forums.ni.com/t5/LabVIEW/LabVIEW-Tutorials-Programming-an-Arduino-using-LINX/m-p/3959118#M11...
I have posted several videos on how to program an Arduino using LabVIEW and the LINX add-on.
Particularly follow the first video where I show you the steps to install LINX and upload the firmware to your Arduino.
Please let me know if you have any questions.
Best Regards,
Sin | Electrical Engineer & Principal Consultant
(5,676 Views)
Sinc- your video is very helpful- however, it does not answer the problem that Belinak posted about. I am having the same issue.
when you use the firmware wizard the wizard open in the front panel as if we were trying to edit the wizard. it is not actually launching the wizard.
do you have any thoughts?
Thank you
(4,426 Views)
Hi, did you find the solution to the given issue?
(1,958 Views)
