LabVIEW Interface for Arduino Discussions
KELLER Pressure transducer interface
Hi all,
I am new to I2C communication.
I need to interface KELLER transducer to Arduino via I2C to measure pressure, I have write a simple LABVIEW and there is NO output reading from LABVIEW and there is and timeout error ( default value is 1000ms) as well. I have no idea why? please advice.
I have attached a screenshot for the reference.
I2C Read for LINX configure as below
1. I2C Channel = 1
2. Bytes = 128
3. I2C Slave address = x43
4. Timeout = 1000ms
Error Message as below,
I2C Read.vi >>
I2C Read.vi<ERR>
A timeout occured while waiting for the Arduino Nano to respond.
The Arduino Nanodid not receive all 128 I2C bytes before the specified tiemout (1000ms)
MAny Thanks.
Walter.
(4,686 Views)
For help with LINX, you should post in the LINX forums.  When you do post, it is often helpful to post a link to the sensor's datasheet.
Hint:  The I2C channel should be zero (0).
(4,119 Views)
Okay..Thanks alot Nathan
(4,119 Views)
