LabVIEW Interface for Arduino Discussions
Interfacing TC directly with arduino without any extra circuitary involved.
Which device are you referring to that has a price of US$1,000.00?
An op amp is a much better method for amplifying the output of a TC than a transistor.  For example:
<http://circuits.linear.com/26>
If you use this circuit in a room with constant temperature you could eliminate the cold junction compensation.  And if required you could use a programmable gain op amp.
Most IC TC amplifiers designed for industrial applications provide cold junction compensation for only one type of TC for cost and accuracy reasons.  For example:
<http://www.analog.com/en/press-release/5_26_10_Precision_Thermocouple_Amplifiers_with_Int/press.html>
These units even compensate for TC non linearities.  Single unit price is US$5.00.
The MAX31855 will work with both type K and type J thermocouples.  See:
<http://www.adafruit.com/datasheets/MAX31855.pdf>
An op amp provides the cost method for amplifying the output of a TC.  But it has the lowest accuracy of the three approaches listed above.
hrh1818
Message 11 of 13
(2,119 Views)
Wen using an op amp in your application software cold junction compensation may be substituted for hard ware cold junction compensation. One could use a temperature sensor like a TMP36 to measure the cold junction temperature and then use software to compensate for variations in ambient temperature. See:
<https://www.sparkfun.com/products/10988?gclid=CP3Kq6XTgroCFZFFMgod3WgA1Q>
<http://paginas.fe.up.pt/saic/Docencia/ci_lem/Ficheiros/an043.pdf>
hrh1818
Message 12 of 13
(2,119 Views)
Thanks a lot all. Will get bac kto you if any other problem
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 13 of 13
(2,119 Views)
