‎04-01-2014 01:03 PM
LIFA will not work with most L298 type motor shields. LIFA will only work with Easy Drive boards and possibly with Adafruit motor shields. To use a L298 you will need to get a sketch that runs on a Arduino board and create a Labview VI to control a step motor. If you tell us what motor shield you are using or if you are using a do it yourself L298 board we can help you find a sketch that will work with what you have?
hrh18918
‎04-01-2014 01:35 PM
Hello sir. Let me share what i did so far.
i am trying to control the stepper motor with an IC of l298N which i did myself on the breadboard. I already try it and it is working fine. I did try with the sample of one revolution from the arduino.
My problem here is that i have to control it using labview. I wanted to do a simple coding before interfacing it in my final prototype and GUI.
i am trying to say an angle and then the motor has to move accordingly. I also have got the sample vi on the labview example.
Using LIFA, i try to upload and edit the code. I dont know how to upload it. should i take snapshot.
** LVFA_Firmware - Provides Basic Arduino Sketch For Interfacing With LabVIEW.
** Written By: Sam Kristoff - National Instruments
** Written On: November 2010
** Last Updated: Dec 2011 - Kevin Fort - National Instruments
** This File May Be Modified And Re-Distributed Freely. Original File Content
** Written By Sam Kristoff And Available At www.ni.com/arduino.
** Includes.
// Standard includes. These should always be included.
#include <Wire.h>
#include <SPI.h>
#include <Servo.h>
#include <Stepper.h>
#include "LabVIEWInterface.h"
const int stepsPerRevolution = 150; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8,9,10,11);
int pic16f877 =3;
int L293D=4;
int pic16f877_state;
int L293D_state;
int posit;
** setup()
** Initialize the Arduino and setup serial communication.
** Input: None
** Output: None
void setup()
// Initialize Serial Port With The Default Baud Rate
syncLV();
// Place your custom setup code here
// set the speed at 60 rpm:
myStepper.setSpeed(80);
pinMode(pic16f877,OUTPUT);
pinMode(L293D,OUTPUT);
digitalWrite(pic16f877,LOW);
digitalWrite(L293D,LOW);
** loop()
** The main loop. This loop runs continuously on the Arduino. It
** receives and processes serial commands from LabVIEW.
** Input: None
** Output: None
void loop()
// Check for commands from LabVIEW and process them.
pic16f877_state = digitalRead(pic16f877);
L293D_state = digitalRead(L293D);
checkForCommand();
// Place your custom loop code here (this may slow down communication with LabVIEW)
if(pic16f877_state==HIGH)
if(posit==0)
myStepper.step(stepsPerRevolution);
posit=1;
if(posit==2)
myStepper.step(-stepsPerRevolution);
posit=1;
if(L293D_state==HIGH)
if(posit==0)
posit=2;
if(posit==1)
posit=2;
if(acqMode==1)
sampleContinously();
‎04-01-2014 01:37 PM
‎04-01-2014 01:43 PM
Actually the code of the PIC all that. This is specifc QR code which i want to be sorted. I did my whole GUI in labview where i am decoding the qr code using vision acquisition. Hence i wanted to use lifa so that
once that specific qr code is scanned and is matched, it is sorted using a rotated wheel type motored by a stepper accordingly to the specific compartment.
‎04-10-2014 12:02 AM
my previous posts were left unawered
Dear Sir
i saw your comment for the stepper motor. Actually i am trying to control the stepper motor using the LIFA. My problem is that i did the coding separetely in arduino and also did my circuit.
But now i am having problem like how to integrate this coding to LIFA.
Hope to hear from you soon
‎04-10-2014 04:24 PM
I can mot help you with modifying LIFA for use with an L298N IC.
hrh1818
‎04-10-2014 06:22 PM
Okay Sir
Is there any recomendation of it sir. Because i try to check online but couldnt make my own
coding successful
Hope to hear a positive response.
‎04-11-2014 08:02 PM
There is an example for the L298 in Documents.
hrh1818
‎04-12-2014 04:22 AM
Dear Sir
thank you very much for replying. Sir i cant see any document which you are refering too.
Can you please guide me again
thank you
