LabVIEW Interface for Arduino Discussions
I want to use thermocouple with max 6675 and arduino uno r3 in labview
Hi Every one
Can you show me how to use thermocouple with max 6675 and arduino uno r3 in labview together
please let me know and if you have block diagram please let me know
Thank you very much
Message 1 of 18
(13,350 Views)
Hey Pakron10,
What part are you having trouble with?  The MAX6675 looks like it uses SPI so you'll want to use the SPI VIs in LIFA or LINX and check out the 6675 for the commands you need to send to the sensor.
-Sam K
LabVIEW Hacker
Join / Follow the LabVIEW Hacker Group on google+
Message 2 of 18
(8,315 Views)
can you show me block diagram? please
Message 3 of 18
(8,315 Views)
I don't have the sensor and have not written any code for it, but if you let us know what you've tried what is not working the way you think it should and what questions you have we'll do your best to help you figure it out.
Thanks!
-Sam K
LabVIEW Hacker
Message 4 of 18
(8,315 Views)
Page one of the following link shows a block diagram.
<https://www.sparkfun.com/datasheets/IC/MAX6675.pdf>
The block diagram uses a 68HC microcotroller.  For an Arduino Uno use the following pin numbers.
MAX6675           Arduino Uno    Arduino
Signal Name      Signal Name   Pin Number
  SO                  MISO                12
  SCK                SCK                  13
  CS                  SSB                  10
Hrh1818
Message 5 of 18
(8,315 Views)
Hi, I try as same as Mr.hrh212 on arduino Uno I have system run seems no problem but, I see nothing from spi data read out. What is wrong? please comment.
Jakkrich S.
Message 6 of 18
(8,315 Views)
Dear Mr.Sammy_K,
      Now my MAX6675 module can sending measured value in degree C, and F through serial monitor of Arduino  editor program perfectly, so I need to get that values into the labview to monitor and keep data to spread sheet. Could you please advise for an example please.
Thank you very much,
Jakkrich S
Message 7 of 18
(8,315 Views)
Hey,
LIFA has been replaced with LINX.  I suggest creating thread on the LINX forums.
Thanks!
-Sam K
Message 8 of 18
(8,315 Views)
In the LINX forum there are 28 MAX6675 messages.  One or more of the messages should answer your questions.
hrh212
Message 9 of 18
(8,315 Views)
Hi, Ni,
Now I use Labview 2012 it can not use Link so Link use of Labview
2014.
Have you any Idea?
Jakkrich Srithongchai
LAE ATR
Nok Air
Message 10 of 18
(8,315 Views)
