LabVIEW Interface for Arduino Discussions
I have an error to domwload IDE to MEGA2560
I follow all steps included in
LabVIEW Interface for Arduino Setup Procedure
The result is
I have an Arduino Mega2560 and LabVIEW 2010. Please, I need support.
Thank you !
Rolando Ariel Ricon
_____________________
(3,318 Views)
When you open "LIFA_Base.ino", it should open all other relevant files in that folder.  If any of these files are not open (in tabs) it will not compile correctly.
I just tried to open only that one file and it always opens all of them so the only thing I can think of with you even being able to open just that one file is that you don't have all the files in that folder.
Also, as an FYI, it appears that you are using an older version of LIFA.  In the latest version, the folder should be called LIFA_Base as opposed to some older versions called LVIFA_Base (and likewise with the main file in this folder).
(2,873 Views)
