LabVIEW Interface for Arduino Discussions
I-V Curve using LINX
Hello, I'm working on diode I-V characteristics project where I need to acquire voltage and current value from my sensors that connected on my arduino, control and display the curve in LabVIEW. I'm using LINX as from my understanding LIFA no longer worked. The issue is I don't understand what to use after the LINX open, i think i should use two peripherals>read>analog read (to get two sensor value from two pin of arduino that connected with two sensors) ? Does analog channel of the analog read indicate the pin number (A0 / A1) of arduino that the sensor connected to? Can anybody show the example or solution? Thank you
(4,224 Views)
Use the "Analog Read N channels.VI" example that comes with LINX.
Next time post your LINX questions in the Maker Hub LINX forum.
hrh212
(3,884 Views)
Thank you . I have posted this in Maker Hub forum.
(3,884 Views)
