LabVIEW Interface for Arduino Discussions
How to write i2c with DAC(MCP4725)
This is our code in arduino  we read the value from potentiometer resistor in voltage(A1) and we need to send this voltage to another circuit  by using DAC (MCP4725).  we connect DAC by i2c but we have a problem.
How to use i2c block diagram in Labview?  we need to send the data to DAC in 4 Byte,  First, Address of DAC (01100000) second, Command (01000000) third, Data last, Data  that you can see in our code.  I don't understand how to write it in labview
(7,152 Views)
For help in writing Labview code for the MCP4725 See:
<htps://decibel.ni.com/content/message/87442#87442>
hrh212
(6,123 Views)
Here is a working version of the link that hrh212 posted.
Also, I highly recommend that you not use LIFA to work with Arduino.  You should use LINX which has replaced LIFA and is actually faster.  The only thing that I don't think it supports [yet] is stepper motors.
(6,124 Views)
hello
please did you solved this problem i need your help, i have the same work
i use DAC MCP4725 with arduino uno
can you give me file .vi
(4,383 Views)
