LabVIEW Interface for Arduino Discussions
Error while reading analog input through arduino to labview.
I didnt connect sensor to analog pin of arduino  but still its showing some analog voltage read by arduino in labview.
(4,270 Views)
That is normal for any analog input (not just Arduino).
P.S. I recommend that you switch to LINX since LIFA is no longer supported (for the last couple years).
(3,690 Views)
I am able to read exact analog voltage if single sensor is connected.But the problem is while connecting multiple sensors, the analog voltage on one pin is copied  to another pin even if i didn't disturb another pin.
(3,690 Views)
You'll need to be more specific about what exactly you have hooked (the
sensors) and to which pins as well as which pins you are reading and what
values you are getting on those pins.
(3,690 Views)
Thank you for your valuable suggestion, telling to switch over to LINX.Just now i tried with LINX i got best results with out errors.
(3,690 Views)
