LabVIEW Interface for Arduino Discussions
Error 5005
How similar did you end up making it?  Does Mac OS not register the Arduino the same as a Windows OS?
Message 11 of 15
(1,489 Views)
Well, it seems like when your run init it checks whether it is an Arduino by comparing the "Arduino" string with the Intf Inst Name. That wasn't working for me, so I coded my own (I wanted to understand how the library worked) just to test whether I could see what the description is on a Mac, but it doesn't seem to be able to pull that information. All mine does is just check which port it is connected to.
Message 12 of 15
(1,489 Views)
It's not that similar, as I was just using it to find the address and then going back to my program that uses the library where I feed a string containing the location into init's VISA resource.
Message 13 of 15
(1,489 Views)
I'm pretty sure I figured out the problem. I hadn't properly installed the NI-Serial, so I uninstalled and re-installed it and now COM6 appears in the drop-down menu. Thank you guys very much! I really appreciate your help.
Message 14 of 15
(1,489 Views)
I'm learning how to connect arduino with labview and I'm getting some problems, basiclly I'm a begginer in this and started using Labview like a week or 2 ago..
I'm using a Seeeduino Stalker v2.1 and I'm getting the same errors (5002 and 5003).
I've been trying to run this basic example:http://minuteeng.blogspot.pt/2012/07/turning-on-and-off-led-of-arduino-using_17. html by changing the pin where the led is on the board (from 13 to 8). I'm using Labview 2011 (64bit).
I've been stuck in thins for a while and i'm not beeing able to solve it.
any ideas of what I might be doing wrong?
Regards.
Message 15 of 15
(1,489 Views)
