LabVIEW Interface for Arduino Discussions
Error 5003 (time out error)
Hey,
So we keep receiving the 5003 error that the arduino is timing out. We are using the bluetooth btm 182 to send the bluetooth signal from the arduino uno.
We are running the Analog Read Pin VI and have all VISA/arduino resources set to COM8, which we believe to be correct. We think we received data once when they arduino was plugged in via USB, but were unable to reproduce it. The baudrate is 115200.
We are not sure what the issue is, but we think that arduino might not be sending data.
Is there any way to know if labview is sending the signal to the arduino to start sending data over bluetooth?
Thanks in advance!
(4,141 Views)
If you are connecting to the arduino over bluetooth I would try slowing down the baud rate - maybe 9600
Kevin Fort
Principal Software Engineer
NI
(3,149 Views)
