LabVIEW Interface for Arduino Discussions
Error 5003 Labview Arduino Servomotor
Hello World,
I am new to Arduino and Labview and I have an Arduino Uno  , I uploaded the LIFA firmware and  I am trying to control a servomotor ( Tower pro 9g) using the servo example but I am receiving the following error
Error 5003 occurred at LabVIEW Interface for Arduino.lvlib:Servo Read Angle.viLabVIEW Interface for Arduino.lvlib:Servo Write Angle.viLabVIEW Interface for Arduino.lvlib:Detach Servo.viLabVIEW Interface for Arduino.lvlib:Configure Servo.viLabVIEW Interface for Arduino.lvlib:Set Number of Servos.viLabVIEW Interface for Arduino.lvlib:Init.vi.  A timeout occurred while trying to read form the Arduino.
The VI worked only when I disconnect the servomoter from Arduino. I tried to use the example code "sweep " in the arduino development environment and it worked also. Can you help me.
(6,782 Views)
LIFA has not been updated for a few years now (it has been replaced).  You should use LINX.  http://www.labviewmakerhub.com/linx
(5,945 Views)
Thank you Nathan_B. if I use LINX , will I lose the VI in which I used LIFA components ?
(5,945 Views)
You can have both installed at the same time. It won't affect your saved
code.
(5,945 Views)
