LabVIEW Interface for Arduino Discussions
Showing results forĀ
Search instead forĀ
Did you mean:Ā
Controling a DC motor with encoder on back
Hello hrh1818,
I'm trying to make an quadrature counter with UPD4702 and UPD 4704 (16 BITs) but I cannot count . I'm using oscilloscope and I have Danaher Controls series 21.
If you have any advice for STB and OE wil be welcome.I did't find any link with industrial electronic prints with those circuits.
Thank you
onu15@yahoo.com
Message 31 of 46
(2,292 Views)
There is a NEC data sheet for the UPD4702 at <http://www.soiseek.com/NEC/UPD4702/> that provides more information than the Renesas data sheet.  It is a 16 page data sheet, of which 3 are blank sheets.  Use the naviagation links in the upper right and lower right corners to browse the data sheet.  In particular look at page 9.  Page 9 shows a simple application circuit.
hrh1818
Message 32 of 46
(2,292 Views)
Dear hrh1818
My project is almost finished.
No I have a problem with motor, when I press run button the motor moves fast (until program load) for a seconds then stops and stays ready for commands by software.
My question is if I can eliminate this fast moving at the beginning before the program loads completely?
Best
CPalha
Message 33 of 46
(2,292 Views)
Hi my friends
After receiving many private messages here is my final project.
Best
cpalha
Message 34 of 46
(2,292 Views)
Hello everyone.
I am having problem. I have to program encoded dc gear motor using arduino and then interface
it in the labview.
First i am having problem. i dont know how to program the encoded dc geared motor with arduino
i am having many problem to even search for the program online. can some1 please help me out
Message 35 of 46
(2,292 Views)
Encoders are not natively supported by LIFA but I have successfully used them with LIFA by adding functions in the firmware and in LabVIEW.  I created a Document about them here (click on the Documents tab).
Message 36 of 46
(2,292 Views)
sir i cant see any attached document.
did u programmed using labview or arduino
Message 37 of 46
(2,292 Views)
It was programmed for the LabVIEW Interface for Arduino (LIFA).  Here is the document.
Message 38 of 46
(2,292 Views)
thank u very much sir. I will check the document you send me.
Sir i wanted to ask. Wat do u mean by Lifa.
for the coding, i have to program using arduino and then interface it
on labview. When i am checking it online. I am unable to understand.
This is the motor i need to program like i attached previously. do u
have some tutorial which you can pass me sir.
Message 39 of 46
(2,292 Views)
my arduino is uno sir
Message 40 of 46
(2,292 Views)
