LabVIEW Interface for Arduino Documents
Basic DC Motor, with PWM (CCW & CW)
I want to share a basic code for PWM control with a DC motor, through a Shield (L293 & L298).
I Use a DFROBOT Shield.
http://www.dfrobot.com/index.php?route=product/product&product_id=69#.UTkCM9GcHrs
My setup is Arduino uno R3, Labview 2010 on MacOS
Regards
Rafael
Mexico
Comments
sraque
Member
Member
on
This worked really well for me. Thanks!
Nathan_B.
Active Participant
Active Participant
on
You forgot to set the pin mode for all the digital pins.  I posted a cleaned up version and a solution to one issue here.
atm5012
Member
Member
on
Can this be done with the adafruit motor shield 2.0?  I would like the accomplish the same functionality i.e. DC motor speed and direction control with Labview.  Not sure which digital pins should be used with this shield.
hrh1818
Active Participant
Active Participant
on
At the present time LIFA  provides support for using stepper motors with the Adafruit motor shield but not DC motors..  If you must use LIFA than you would need to add support for DC motors to the LIFA code.
Or you could use the serial monitor capability of Labview to send commands to a sketch running on an Arduino Uno to control a DC motor.
hrh1818
kevinlc
Member
Member
on
It is very useful! Thanks
zohair360
Member
Member
on
thanks, worked perfectly!!
Zhoo99
Member
Member
on
Hi, I am asking whene I use arduino with the shield L298P it work fine, but with "NI MyRIO" It dosn't work at all ?
I tryed the simple way :
get the pins [4 5 6 7] at "High"
with "arduino" both of 2 motors turn with full speed and same direction
measurements: [3.4 v at pins 4 5 6 7]
with "My RIO" ... nothing happened
measurements: [3.1 v at pins 4, 7] and [2.8v at pins 5, 6].
any ideas guys
harbi
Member
Member
on
hi
can  you help me by  how  i can generat PWN  by using serial port (VISA)
arduino and labview
Zhoo99
Member
Member
on
here is my skype " benzo-25" i will try to help you
2016-01-07 7:15 GMT+01:00 harbi <web.community@ni.com>:
NI Community <https://decibel.ni.com/content/index.jspa> Basic DC Motor,
with PWM (CCW & CW) new comment by harbi
<https://decibel.ni.com/content/people/harbi> View all comments on this
document <https://decibel.ni.com/content/docs/DOC-27770#comment-46667>
Contributors
