LabVIEW Interface for Arduino Discussions
Arduino and Dallas DS1820 (one-wire)
I am trying to get this work also.  However, I have not been able to yet.  I am getting error 5003 when it is running.
Message 21 of 172
(5,486 Views)
IIRC, to prevent this (in many cases) make sure you never use the "Abort Execution" button when running anything with LIFA.
If restarting everything doesn't help, are you able to use the blink example with the Arduino?
Message 22 of 172
(5,486 Views)
Hi everyone!
It was not obligatory for me to use the DS1820 to measure temperature, so to give a fast solution to that issue, I simply used a thermistor in one of the analogic input.
Anyway I hope this thread finishes with a clear and complete solution for the DS1820. (I think it is by far a much better sensor than a simple thermistor)
If there is anyone interested to see my first LabVIEW program, I can attach the link to the video in another message.
DMDsync
Message 23 of 172
(5,486 Views)
Hi guys!
DMDsync: please, send the video!
I'm trying use the DS1820 but I can't!
I'm looking for another solution..
Thanks!
Message 24 of 172
(5,486 Views)
Hi guys!
Someone could use the Dallas DS1820 (one-wire) with arduino?
I tried as in the tutorial, but it did not work
I had to re-install my LIFA
Message 25 of 172
(5,486 Views)
Hey lucagvf2!!
I forgot to mention that the video is in spanish so I'm not sure if it will be of help to you. I used a simple LM35 to suit my goals. The purpose of the video was to show my first LabVIEW program, and what I was able to measure (I also could store some data on an excel file). It is not a tutorial of how to make the program.
Anyway if you still think it would be helpful for you, I will copy the link.
Refering to the question in your second message, I can say that I was able to use the DS1820 together with Arduino but not with LIFA. I was able to adapt an example of a serial comunication to send the data from the DS1820 to LabVIEW.
I hope you can find the way to fully interface the DS1820 with LabVIEW using LIFA.
best regards!
DMDsync
Message 26 of 172
(5,486 Views)
Hi there,
I also tried to get the Dallas DS1820 working (and it works perfectly when using the Dallas Temp Sensor Library) but I don't get it running with LVIFA. I followed the instructions and modified both LVIFA_Base.pde (ino) and LabviewInterface.h.Please find attached the codes and the vi.
Please help - I spent a week after-work-playing-around and I still don't get it...
Thanks heaps!
Daniel
**  LVFA_Firmware - Provides Basic Arduino Sketch For Interfacing With LabVIEW.
**  Written By:    Sam Kristoff - National Instruments
**  Written On:    November 2010
**  Last Updated:  Dec 2011 - Kevin Fort - National Instruments
**  This File May Be Modified And Re-Distributed Freely. Original File Content
**  Written By Sam Kristoff And Available At www.ni.com/arduino.
** Includes.
// Standard includes.  These should always be included.
#include <Wire.h>
#include <SPI.h>
#include <Servo.h>
#include <OneWire.h>
#include <TFT_Graphics.h>
#include "LabVIEWInterface.h"
**  setup()
**  Initialize the Arduino and setup serial communication.
**  Input:  None
**  Output: None
void setup()
  // Initialize Serial Port With The Default Baud Rate
  syncLV();
  // Place your custom setup code here
**  loop()
**  The main loop.  This loop runs continuously on the Arduino.  It
**  receives and processes serial commands from LabVIEW.
**  Input:  None
**  Output: None
void loop()
  // Check for commands from LabVIEW and process them.
  checkForCommand();
  // Place your custom loop code here (this may slow down communication with LabVIEW)
  if(acqMode==1)
    sampleContinously();
**  LVIFA_Firmware - Provides Functions For Interfacing With The Arduino Uno
#include <Wire.h>
#include <SPI.h>
#include <LiquidCrystal.h>
// Variables
unsigned int retVal;
//int sevenSegmentPins[8];
int currentMode;
unsigned int freq;
unsigned long duration;
int i2cReadTimeouts = 0;
char spiBytesToSend = 0;
char spiBytesSent = 0;
char spiCSPin = 0;
char spiWordSize = 0;
//Servo *servos;
byte customChar[8];
LiquidCrystal lcd(0,0,0,0,0,0,0);
// Sets the mode of the Arduino (Reserved For Future Use)
void setMode(int mode)
  currentMode = mode;
// Checks for new commands from LabVIEW and processes them if any exists.
int checkForCommand(void)
#ifdef STEPPER_SUPPORT
  // Call run function as fast as possible to keep motors turning
  for (int i=0; i<8; i++){
   // steppers.run();
#endif
  int bufferBytes = Serial.available();
  if(bufferBytes >= COMMANDLENGTH)
    // New Command Ready, Process It
    // Build Command From Serial Buffer
    for(int i=0; i<COMMANDLENGTH; i++)
      currentCommand = Serial.read();
    processCommand(currentCommand);
    return 1;
  else
    return 0;
// Processes a given command
void processCommand(unsigned char command[])
  // Determine Command
  if(command[0] == 0xFF && checksum_Test(command) == 0)
    switch(command[1])
    ** LIFA Maintenance Commands
    case 0x00:     // Sync Packet
      Serial.print("sync");
      Serial.flush();
      break;
    case 0x01:    // Flush Serial Buffer
      Serial.flush();
      break;
    ** Low Level - Digital I/O Commands
    case 0x02:    // Set Pin As Input Or Output
      pinMode(command[2], command[3]);
      Serial.write('0');
      break;
    case 0x03:    // Write Digital Pin
      digitalWrite(command[2], command[3]);
       Serial.write('0');
      break;
    case 0x04:    // Write Digital Port 0
      writeDigitalPort(command);
       Serial.write('0');
      break;
    case 0x05:    //Tone
      freq = ( (command[3]<<8) + command[4]);
      duration=(command[8]+  (command[7]<<8)+ (command[6]<<16)+(command[5]<<24));
      if(freq > 0)
        tone(command[2], freq, duration);
      else
        noTone(command[2]);
       Serial.write('0');
      break;
    case 0x06:    // Read Digital Pin
      retVal = digitalRead(command[2]);
      Serial.write(retVal);
      break;
    case 0x07:    // Digital Read Port
      retVal = 0x0000;
      for(int i=0; i <=13; i++)
        if(digitalRead(i))
          retVal += (1<<i);
      Serial.write( (retVal & 0xFF));
      Serial.write( (retVal >> 8));
      break;
    ** Low Level - Analog Commands
    case 0x08:    // Read Analog Pin
      retVal = analogRead(command[2]);
      break;
    case 0x09:    // Analog Read Port
      analogReadPort();
      break;
    ** Low Level - PWM Commands
    case 0x0A:    // PWM Write Pin
      analogWrite(command[2], command[3]);
       Serial.write('0');
      break;
    case 0x0B:    // PWM Write 3 Pins
      analogWrite(command[2], command[5]);
      analogWrite(command[3], command[6]);
      analogWrite(command[4], command[7]);
       Serial.write('0');
      break;
    ** Sensor Specific Commands
    //case 0x0C:    // Configure Seven Segment Display
      //sevenSegment_Config(command);
      // Serial.write('0');
      //break;
    //case 0x0D:    // Write To Seven Segment Display
     // sevenSegment_Write(command);
      //break;
    **  I2C
    case 0x0E:    // Initialize I2C
      Wire.begin();
       Serial.write('0');
      break;
    case 0x0F:    // Send I2C Data
      Wire.beginTransmission(command[3]);
      for(int i=0; i<command[2]; i++)
        #if defined(ARDUINO) && ARDUINO >= 100
          Wire.write(command[i+4]);
        #else
          Wire.send(command[i+4]);
        #endif
      Wire.endTransmission();
       Serial.write('0');
      break;
    case 0x10:    // I2C Read
      Wire.requestFrom(command[3], command[2]);
      while(Wire.available() < command[2])
        i2cReadTimeouts++;
        if(i2cReadTimeouts > 100)
          return;
        else
          delay(1);
          Serial.write(Wire.read());
        #else
          Serial.write(Wire.receive());
        #endif
      break;
    ** SPI
    case 0x11:    // SPI Init
      SPI.begin();
       Serial.write('0');
      break;
    case 0x12:    // SPI Set Bit Order (MSB LSB)
      if(command[2] == 0)
        SPI.setBitOrder(LSBFIRST);
      else
        SPI.setBitOrder(MSBFIRST);
       Serial.write('0');
      break;
    case 0x13:    // SPI Set Clock Divider
      spi_setClockDivider(command[2]);
       Serial.write('0');
      break;
    case 0x14:    // SPI Set Data Mode
      switch(command[2])
      case 0:
        SPI.setDataMode(SPI_MODE0);
        break;
      case 1:
        SPI.setDataMode(SPI_MODE1);
        break;
      case 2:
        SPI.setDataMode(SPI_MODE2);
        break;
      case 3:
        SPI.setDataMode(SPI_MODE3);
        break;
      default:
        break;
       Serial.write('0');
      break;
    case 0x15:  // SPI Send / Receive
      spi_sendReceive(command);
      break;
    case 0x16:  // SPI Close
      SPI.end();
       Serial.write('0');
      break;
    ** Servos
   // case 0x17:  // Set Num Servos
    //  free(servos);
    //  servos = (Servo*) malloc(command[2]*sizeof(Servo));
    //  for(int i=0; i<command[2]; i++)
    //    servos = Servo();
     // if(servos == 0)
    //    Serial.write('1');
    //  else
    //  break;
    case 0x18:  // Configure Servo
     // servos[command[2]].attach(command[3]);
      break;
    case 0x19:  // Servo Write
     // servos[command[2]].write(command[3]);
      break;
    case 0x1A:  // Servo Read Angle
    //  Serial.write(servos[command[2]].read());
      break;
    case 0x1B:  // Servo Write uS Pulse
    //  servos[command[2]].writeMicroseconds( (command[3] + (command[4]<<8)) );
      break;
    case 0x1C:  // Servo Read uS Pulse
   //   retVal = servos[command[2]].readMicroseconds();
    //  Serial.write ((retVal & 0xFF));
    //  Serial.write( (retVal >> 8));
      break;
    case 0x1D:  // Servo Detach
   //   servos[command[2]].detach();
      break;
         **                                      LCD
    case 0x41: // color command HEX code
        initialize(LCD_HORIZONTAL);
        ClearScreen(BLACK);
        break;
    case 0x1E:  // LCD Init
        lcd.init(command[2], command[3], command[4], command[5], command[6], command[7], command[8], command[9], command[10], command[11], command[12], command[13]);
        Serial.write('0');
        break;
      case 0x1F:  // LCD Set Size
        lcd.begin(command[2], command[3]);
        Serial.write('0');
        break;
      case 0x20:  // LCD Set Cursor Mode
        if(command[2] == 0)
          lcd.noCursor();
        else
          lcd.cursor();
        if(command[3] == 0)
          lcd.noBlink();
        else
          lcd.blink();
        Serial.write('0');
        break;
      case 0x21:  // LCD Clear
        lcd.clear();
        Serial.write('0');
        break;
      case 0x22:  // LCD Set Cursor Position
        lcd.setCursor(command[2], command[3]);
        Serial.write('0');
        break;
      case 0x23:  // LCD Print
        lcd_print(command);
        break;
      case 0x24:  // LCD Display Power
        if(command[2] == 0)
          lcd.noDisplay();
        else
          lcd.display();
        Serial.write('0');
        break;
      case 0x25:  // LCD Scroll
        if(command[2] == 0)
          lcd.scrollDisplayLeft();
        else
          lcd.scrollDisplayRight();
        Serial.write('0');
        break;
      case 0x26: //  LCD Autoscroll
        if(command[2] == 0)
          lcd.noAutoscroll();
        else
          lcd.autoscroll();
        Serial.write('0');
        break;
      case 0x27: // LCD Print Direction
        if(command[2] == 0)
          lcd.rightToLeft();
        else
          lcd.leftToRight();
        Serial.write('0');
        break;
      case 0x28: // LCD Create Custom Char
        for(int i=0; i<8; i++)
          customChar = command[i+3];
        lcd.createChar(command[2], customChar);
        Serial.write('0');
        break;
      case 0x29:  // LCD Print Custom Char
        lcd.write(command[2]);
        Serial.write('0');
        break;
    ** Continuous Aquisition
      case 0x2A:  // Continuous Aquisition Mode On
        acqMode=1;
        contAcqPin=command[2];
        contAcqSpeed=(command[3])+(command[4]<<8);
        acquisitionPeriod=1/contAcqSpeed;
        iterationsFlt =.08/acquisitionPeriod;
        iterations=(int)iterationsFlt;
        if(iterations<1)
          iterations=1;
        delayTime= acquisitionPeriod;
       if(delayTime<0)
         delayTime=0;
        break;
      case 0x2B:  // Continuous Aquisition Mode Off
        acqMode=0;
        break;
     case 0x2C:  // Return Firmware Revision
         Serial.write(byte(FIRMWARE_MAJOR));
         Serial.write(byte(FIRMWARE_MINOR));
        break;
     case 0x2D:  // Perform Finite Aquisition
         Serial.write('0');
         finiteAcquisition(command[2],(command[3])+(command[4]<<8),command[5]+(command[6]<<8));
        break;
    ** Stepper
//   #ifdef STEPPER_SUPPORT
  //    case 0x30:  // Configure Stepper
  //      if (command[2] == 5){    // Support AFMotor Shield
  //        switch (command[3]){
   //       case 0:
   //         steppers[command[3]] = AccelStepper(forwardstep1, backwardstep1);
   //         break;
   //       case 1:
   //         steppers[command[3]] = AccelStepper(forwardstep2, backwardstep2);
   //         break;
   //       default:
   //         break;
     //   else if(command[2]==6) {                   // All other stepper configurations
     //     steppers[command[3]] = AccelStepper(1, command[4],command[5],command[6],command[7]);
     //   else{
     //     steppers[command[3]] = AccelStepper(command[2], command[4],command[5],command[6],command[7]);
     //   break;
     // case 0x31:  // Stepper Write
     //   AccelStepper_Write(command);
     //   break;
     // case 0x32:  // Stepper Detach
     //   steppers[command[2]].disableOutputs();
     //   break;
     // case 0x33:  // Stepper steps to go
     //   retVal = 0;
     //   for(int i=0; i<8; i++){
     //     retVal += steppers.distanceToGo();
      //  Serial.write( (retVal & 0xFF) );
      //  Serial.write( (retVal >> 😎 );
    //    break;
   // #endif
case 0x42:  // OneWire Read
        OneWire_Read();
        break;
    ** Unknown Packet
    default:      // Default Case
      Serial.flush();
      break;
  else{
    // Checksum Failed, Flush Serial Buffer
    Serial.flush();
**  Functions
//void ini_and_send_color()
//  tft.initialize(LCD_HORIZONTAL);
//  delay(5000);
//  tft.ClearScreen(BLACK); //Send color BLACK
//  delay(5000);
// Writes Values To Digital Port (DIO 0-13).  Pins Must Be Configured As Outputs Before Being Written To
void writeDigitalPort(unsigned char command[])
  digitalWrite(13, (( command[2] >> 5) & 0x01) );
  digitalWrite(12, (( command[2] >> 4) & 0x01) );
  digitalWrite(11, (( command[2] >> 3) & 0x01) );
  digitalWrite(10, (( command[2] >> 2) & 0x01) );
  digitalWrite(9, (( command[2] >> 1) & 0x01) );
  digitalWrite(8, (command[2] & 0x01) );
  digitalWrite(7, (( command[3] >> 7) & 0x01) );
  digitalWrite(6, (( command[3] >> 6) & 0x01) );
  digitalWrite(5, (( command[3] >> 5) & 0x01) );
  digitalWrite(4, (( command[3] >> 4) & 0x01) );
  digitalWrite(3, (( command[3] >> 3) & 0x01) );
  digitalWrite(2, (( command[3] >> 2) & 0x01) );
  digitalWrite(1, (( command[3] >> 1) & 0x01) );
  digitalWrite(0, (command[3] & 0x01) );
// Reads all 6 analog input ports, builds 8 byte packet, send via RS232.
void analogReadPort()
  // Read Each Analog Pin
  int pin0 = analogRead(0);
  int pin1 = analogRead(1);
  int pin2 = analogRead(2);
  int pin3 = analogRead(3);
  int pin4 = analogRead(4);
  int pin5 = analogRead(5);
  //Build 8-Byte Packet From 60 Bits of Data Read
  char output0 = (pin0 & 0xFF);
  char output1 = ( ((pin1 << 2) & 0xFC) | ( (pin0 >> 😎 & 0x03) );
  char output2 = ( ((pin2 << 4) & 0xF0) | ( (pin1 >> 6) & 0x0F) );
  char output3 = ( ((pin3 << 6) & 0xC0) | ( (pin2 >> 4) & 0x3F) );
  char output4 = ( (pin3 >> 2) & 0xFF);
  char output5 = (pin4 & 0xFF);
  char output6 = ( ((pin5 << 2) & 0xFC) | ( (pin4 >> 😎 & 0x03) );
  char output7 = ( (pin5 >> 6) & 0x0F );
  // Write Bytes To Serial Port
  Serial.print(output0);
  Serial.print(output1);
  Serial.print(output2);
  Serial.print(output3);
  Serial.print(output4);
  Serial.print(output5);
  Serial.print(output6);
  Serial.print(output7);
// Configure digital I/O pins to use for seven segment display
//void sevenSegment_Config(unsigned char command[])
  // Configure pins as outputs and store in sevenSegmentPins array for use in sevenSegment_Write
  //for(int i=2; i<10; i++)
    //pinMode(command, OUTPUT);
    //sevenSegmentPins[(i-1)] = command;
//  Write values to sevenSegment display.  Must first use sevenSegment_Configure
//void sevenSegment_Write(unsigned char command[])
  //for(int i=1; i<9; i++)
    //digitalWrite(sevenSegmentPins[(i-1)], command);
// Set the SPI Clock Divisor
void spi_setClockDivider(unsigned char divider)
  switch(divider)
  case 0:
    SPI.setClockDivider(SPI_CLOCK_DIV2);
    break;
  case 1:
    SPI.setClockDivider(SPI_CLOCK_DIV4);
    break;
  case 2:
    SPI.setClockDivider(SPI_CLOCK_DIV8);
    break;
  case 3:
    SPI.setClockDivider(SPI_CLOCK_DIV16);
    break;
  case 4:
    SPI.setClockDivider(SPI_CLOCK_DIV32);
    break;
  case 5:
    SPI.setClockDivider(SPI_CLOCK_DIV64);
    break;
  case 6:
    SPI.setClockDivider(SPI_CLOCK_DIV128);
    break;
  default:
    break;
void spi_sendReceive(unsigned char command[])
  if(command[2] == 1)        //Check to see if this is the first of a series of SPI packets
    spiBytesSent = 0;
    spiCSPin = command[3];
    spiWordSize = command[4];
    // Send First Packet's 8 Data Bytes
    for(int i=0; i<command[5]; i++)
      // If this is the start of a new word toggle CS LOW
      if( (spiBytesSent == 0) || (spiBytesSent % spiWordSize == 0) )
        digitalWrite(spiCSPin, LOW);
      // Send SPI Byte
      Serial.print(SPI.transfer(command[i+6]));
      spiBytesSent++;
      // If word is complete set CS High
      if(spiBytesSent % spiWordSize == 0)
        digitalWrite(spiCSPin, HIGH);
  else
    // SPI Data Packet - Send SPI Bytes
    for(int i=0; i<command[3]; i++)
      // Send SPI Byte
      Serial.write(SPI.transfer(command[i+4]));
      spiBytesSent++;
// Synchronizes with LabVIEW and sends info about the board and firmware (Unimplemented)
void syncLV()
  Serial.begin(DEFAULTBAUDRATE);
  spiBytesSent = 0;
  spiBytesToSend = 0;
  Serial.flush();
// Compute Packet Checksum
unsigned char checksum_Compute(unsigned char command[])
  unsigned char checksum;
  for (int i=0; i<(COMMANDLENGTH-1); i++)
    checksum += command;
  return checksum;
// Compute Packet Checksum And Test Against Included Checksum
int checksum_Test(unsigned char command[])
  unsigned char checksum = checksum_Compute(command);
  if(checksum == command[COMMANDLENGTH-1])
    return 0;
  else
    return 1;
// Stepper Functions
//#ifdef STEPPER_SUPPORT
  //void AccelStepper_Write(unsigned char command[]){
//   int steps = 0;
//   int step_speed = 0;
//   int acceleration = 0;
    //Number of steps & speed are a 16 bit values, split for data transfer. Reassemble 2 bytes to an int 16
  //  steps = (int)(command[5] << 😎 + command[6];
  //  step_speed = (int)(command[2] << 😎 + command[3];
  //  acceleration = (int)(command[7] << 😎 + command[8];
  //  steppers[command[4]].setMaxSpeed(step_speed);
  //  if (acceleration == 0){
      //Workaround AccelStepper bug that requires negative speed for negative step direction
  //    if (steps < 0) step_speed = -step_speed;
  //    steppers[command[4]].setSpeed(step_speed);
  //    steppers[command[4]].move(steps);
  //  else {
  //    steppers[command[4]].setAcceleration(acceleration);
//#endif
void sampleContinously()
  for(int i=0; i<iterations; i++)
     retVal = analogRead(contAcqPin);
     if(contAcqSpeed>1000) //delay Microseconds is only accurate for values less that 16383
       Serial.write( (retVal >> 2));
       delayMicroseconds(delayTime*1000000); //Delay for neccesary amount of time to achieve desired sample rate
     else
        delay(delayTime*1000);
void finiteAcquisition(int analogPin, float acquisitionSpeed, int numberOfSamples)
  //want to exit this loop every 8ms
   acquisitionPeriod=1/acquisitionSpeed;
  for(int i=0; i<numberOfSamples; i++)
     retVal = analogRead(analogPin);
     if(acquisitionSpeed>1000)
       delayMicroseconds(acquisitionPeriod*1000000);
     else
       delay(acquisitionPeriod*1000);
void lcd_print(unsigned char command[])
  if(command[2] != 0)
    // Base Specified By User
    int base = 0;
    switch(command[2])
      case 0x01:  // BIN
        base = BIN;
        break;
      case 0x02:  // DEC
        base = DEC;
        break;
      case 0x03:  // OCT
        base = OCT;
        break;
      case 0x04:  // HEX
        base = HEX;
        break;
      default:
        break;
      lcd.print(command[i+4], base);
  else
      lcd.print((char)command[i+4]);
  Serial.write('0');
void initialize(uint8_t orient)
    LCD::SetOrientation(orient);
    LCD::SetColor(WHITE);
    LCD::init();
void ClearScreen(uint16_t color)
    LCD::resetArea();
    LCD::fill(LCD::GetWidth()-1, LCD::GetHeight()-1, color);
void OneWire_Read()// Funcion para leer desde el sensor DS1820
  OneWire ds(2);          // Create a OneWire Object "ds" on pin 2.  Hard coding for now, because I can't declare this in a case.
  byte OneWireData[9];    // Defining stuff for the added OneWire function because I'm getting irritated with trying to make this fit into a case or function.
  int Fract, Whole, Tc_100, SignBit, TReading;
    // Start the Conversion
    ds.reset();      // Reset the OneWire bus in preparation for communication
    ds.skip();       // Skip addressing, since there is only one sensor
    ds.write(0x44);  // Send 44, the conversion command
  // Wait for the Conversion
    delay(1000);     // Wait for the conversion to complete
  // Read back the data
    ds.write(0xBE);                  // Send the "Read Scratchpad" command
    for ( byte i = 0; i < 9; i++) {
      OneWireData = ds.read();    // Read the 9 bytes into data[]
  // Scale the data
    TReading = (OneWireData[1] << 😎 + OneWireData[0];
    SignBit = TReading & 0x8000;               // Mask out all but the MSB
    if (SignBit)                                   // If the MSB is negative, take the Two's Compliment to make the reading negative
      TReading = (TReading ^ 0xffff) + 1;          // 2's comp
    Tc_100 = (6 * TReading) + TReading / 4;    // Scale by the sensitivity (0.0625°C per bit) and 100
    Whole = Tc_100 / 100;                      // Split out the whole number portion of the reading
    Fract = Tc_100 % 100;                      // Split out the fractional portion of the reading
  // Return the data serially
    if (SignBit) {              // If the reading is negative, print a negative sign
      Serial.print("-");
    Serial.print(Whole);        // Print the whole number portion and a decimal
    Serial.print(".");
    if (Fract < 10) {            // if the fraction portion is less than .1, append a 0 decimal
      Serial.print("0");
    Serial.print(Fract);        // Otherwise print the fractional portion
Message 27 of 172
(5,486 Views)
Hi, has anyone found a solution? a step by step tutorial to use arduino and this probe?
Thank you.
Message 28 of 172
(5,486 Views)
The solution is in posts 5 and 6.  However, it was written for an older verison of LIFA so you will need to manually insert the new code and appropriately change the command reference number in the firmware code that you add and the LabVIEW VI from post 6.
If you are still unable to figure it out, post your modified firmware code and your VI and I will try to see if I can find anything wrong with it.
Message 29 of 172
(5,486 Views)
Nathan_B, Thanks for the reply. I am a beginner with arduino. I will send the files I changed. I do not send you the VI because i have this error:
LabVIEWInterface.ino: In function 'void processCommand(unsigned char*)':
LabVIEWInterface.ino:150: warning: left shift count >= width of type
LabVIEWInterface:362: error: 'OneWire_Read' was not declared in this scope
LabVIEWInterface:363: error: expected `;' before 'break'
at :
         **                                      Temp
     case 0x1E:  // OneWire Read
        OneWire_Read()
     break;
Message 30 of 172
(5,486 Views)
