LabVIEW Interface for Arduino Discussions
Arduino Lilypad USB and Labview
I'm trying to connect an arduino lilypad usb to LabVIEW using LINX, but am unable to select the lilypad as the working device in firmware wizard. I was just wondering if anyone knew of a way around this problem? I am using the version LabVIEW 2014. Any advice would be much appreciated.
Thanks!
(3,788 Views)
You could try selecting the Leonardo in LINX since it uses the same Atmel 32u4 that the Lilypad uses. If that does not work you should post your questions to the LINX forums.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,763 Views)
Ok thanks I'll try that!
(3,758 Views)
