LabVIEW Interface for Arduino Discussions
Arduino - Labview Error 5003
I'm trying to use my Arduino Uno card with labview. I just want to test the Led13 connected to the PIN13. But I have a Error 5003. The baud Rate is good (default value: 115200) et IDE Arduino is closed.
If someone has any solution, Thank in advance.
Pierre
Message 1 of 40
(36,142 Views)
I had the same problem and solved it with older arduino IDE software version. If you are using new version for example 1.8.7, compilation and download to UNO or Mega are OK, but communication with LabView report bugs 5002 or 5003. If I dowload older version arduino IDE for example 1.0.1, compile project and download to UNO or Mega, connection is OK.
Here are older versions of IDE https://www.arduino.cc/en/Main/OldSoftwareReleases
Miroslav
Message 2 of 40
(35,994 Views)
That really fixes the problem, I've been looking for quite a while, thank you so much!
Message 3 of 40
(35,501 Views)
YOU ARE THE BEST SIR
Message 4 of 40
(33,985 Views)
it totally works, thank you!!
Message 5 of 40
(33,666 Views)
Accepted by Hooovahh
I have found and fixed this error.
It is due to an uninitialized variable "checksum". Read and follow my simple fix instructions.
Good luck.
Thomas Plummer
LabVIEW Developer
Message 6 of 40
(33,595 Views)
Ho installato la versione 1.6.7 di Arduino e il problema si è risolto.
Message 7 of 40
(33,179 Views)
It worked, thank you
Message 8 of 40
(32,957 Views)
You'are the best. Thank you so much. It;s working well at Ardunio IDE 1.8.11
Message 9 of 40
(32,892 Views)
Thank you.. really helped
Message 10 of 40
(32,811 Views)
