LabVIEW Interface for Arduino Discussions
Arduino + LINX SPI communication
Hey yall,
Im working on a school project using an arduino and the linx firmware. I've got the environment working switching relays and such but Im stuck on getting the SPI communication to work. I have a 4 digit 7 segment array I got from sparkfun that accepts SPI data to display characters. I got everything wired up just fine and I can send data but I cant make sense of what is actually happening on the labview side.
More specifically, creating a control for data input gives this
but I dont understand what this is or how it is sending data. The linx SPI config block (which I have setup mostly correct...I think) has the parameter for SPI frame size but so does the write read block...so which do I use (and what does it mean by frame size)?
Ultimately I want to send a 4 digit temperature reading from a thermistor block to the display but obviously I'm new to labview as well as SPI communication. I'm familiar with decimal, binary, hex, etc... but I wont have access to an oscilliscope for another week so I cant really probe whats going on here. Any guidance yall can provide would be greatly appreciated!
The information for my sparkfun display can be found here.
They have a new version that also has I2C capability but mine does not so I am stuck with SPI.
(6,919 Views)
This forum is for LIFA.  If you are using LINX, I recommend that you post in the LINX support forums.
(4,963 Views)
I was using LIFA before I found out that LINX is the newer version. As far as I can tell the SPI blocks are similar between the two besides the icon image.
(4,963 Views)
Where is this fabled LINX forum you speak of?
(4,963 Views)
The main overview page of this community has a description and link for LINX.  There is also a "Featured Discussion" at the top of the Discussions page here that goes a little more indepth with more links.
(4,963 Views)
ahhh, already there.  I was here on NI looking.  Thanks Nathan.
BTW OP did you ever get this working?  Im about to attempt it as well..
(4,963 Views)
