LabVIEW Interface for Arduino Discussions
Arduino I/O Expander with MCP23017 and 74HC4051 and Labview
You are using the wrong baud rate for the Uno.  The Uno uses 115200 for a baud rate.  However, you can also simply delete the inputs for the baud rate and board type and they will default to Uno settings.
Message 11 of 14
(1,831 Views)
Many thanks! Works smoothly both on Uno and Mega.
Message 12 of 14
(1,831 Views)
I have realized that this VI works only with bank-A in "write" and bank-B in "read" mode. No other arrangement is currenly working.
Message 13 of 14
(1,831 Views)
After working with it for a while more, I ended up making sub-vi which can be used to put the MCP23017 in read or write mode (bank A and B in same mode). Now, I can atleast use the IC as a 16 bit input or output from labview thru arduino. I am working on a demo program. I'll upload everything later.
Message 14 of 14
(1,831 Views)
