LabVIEW Interface for Arduino Discussions
Arduino Drivers on Windows 7 x64
Is anybody else having issues installing arduino drivers on Windows 7 64 bit?  We've tried both 0022 and 1.0 versions but neither will install.  It says there is an error but doesn't doesn't really elaborate.
(5,309 Views)
Ok, well, I think I may have figured it out.  I tested on a different machine with the same OS and it worked smoothly.  I've discovered that the computers at school seem to fail at unzipping the files completely (no warnings or errors, just stops and closes the dialog) and is missing files and thus causing my problems.  I will have to test at school tomorrow to see for sure.
(3,622 Views)
My uno works with w764, loaded 2.0 LIFA with arduino 1.0 and use labview LIFA.
However every time I leave my arduino plugged in and the computer goes to sleep it blue screens (that's fun).  It works otherwise if you consider that working.
(3,622 Views)
If you are having consistent issues with the arduino installer I would post up on their support forum since that is definitely something they will want to know about.
Kevin Fort
Principal Software Engineer
NI
(3,622 Views)
