LabVIEW Interface for Arduino Discussions
After Why I download LIFA to Arduino_UNO,Initialization digita_Pin some of the "0", some of the "1" ?
After Why I download LIFA to Arduino_UNO,Initialization digita_Pin some of the "0", some of the "1" ? How to reset all "0"?Need to modify the LIFA_Base? How to change?
Message 1 of 11
(8,181 Views)
What does your LabVIEW code look like?  Have you tried setting their values after you set their pin modes (before your main loop)?
Message 2 of 11
(4,575 Views)
Thank you Mr.Nathan_B's reply
I mean not to write any program in Labview and UNO, After  download LIFA_Base, UNO digital Pin IO port will not reset state. LIFA_Base Bug?
thank you!
Message 3 of 11
(4,576 Views)
I'm not entirely sure I understand what you are saying.  Would I be correct in assuming that you are saying that when you first load LIFA_Base onto the Arduino, the LEDs light up as you have shown in the image above without running any LabVIEW code?
As stated in the Arduino documenation, all digital pins should default to inputs (a high impedance state) and therefore should not be lighting up any LEDs that you have connected to them.
Message 4 of 11
(4,576 Views)
My application is IO port ontrol solenoid valve, if a power on ,IO is not initialized to zero,the solenoid valve action,the machine will be in danger,so the problem has been bothering me,I don't know how to solve it in LIFA_Base.
thank you!
Message 5 of 11
(4,576 Views)
Nathan_B. 编写:
yes, your  understanding is correct,but why the digital Pins is default to outputs?
Message 6 of 11
(4,576 Views)
Mr Nathan_B
I modified the LIFA_Base void setup(),sovled my problem, is that OK?
thank you!
Message 7 of 11
(4,576 Views)
Your edit is perfectly fine.  It just doesn't make sense why they are not defaulting correctly.
Message 8 of 11
(4,576 Views)
I remenber that the same issue was discussed earlier about Mega boot state  :
https://decibel.ni.com/content/message/41624#41624
Pedro gave a countermeasure, but If I remember well, I quickly tried it with not much success.
Your solution sgh81 will probably be more efficient 🙂
regards
antoine
Message 9 of 11
(4,576 Views)
The solution in the other thread will work as long as the Arduino is no rebooted or restarted in some way AFAIK.
Message 10 of 11
(4,576 Views)
